Gatman
I have been gently persuaded and strongly suggested that I swap out my freshly built 700R4 transmission BEFORE I grenade the tranny to a pile of useless parts. My build will be in the 500+hp range and from what everyone is telling me, the stock 700 and converter will never last with that kind of power let alone a few boosted launches. So... a 4L80 is the way to go right?? I'm honestly not so sure. Here is my problem(s)...
1. Buy and rebuild a 4L80
2. Buy and install a new cross member
3. Buy and install a longer/adjustable prop-shaft
4. Buy and install a FAST (or similar) computer to operate the tranny
5. Buy and install a stall converter
6. Shorten my driveshaft
7. Buy and replace the tail shaft
8. Buy and install the adaptor plate
9. Buy and install new shifter linkage and cables
10. Etc. etc.
In my search for a late model 4L80 I have come across several reputable tranny builders online that claim to be able to build a virtually indestructible 700R4 that can handle in excess of 1200hp!! Now these are expensive units as they are essentially all billet construction and use only the best of the best internals (pumps, servos, clutches, converter, etc.). I can get one of these built transmissions anywhere from $3800 to $5500. which obviously is a huge coin, but when you consider the price cost for the list above...
Does anyone have any experience with one of these bulletproof 700R4's? I would MUCH rather simply swap out my stocker with one of these bad boys than go through the hassle of making the conversion. Please share your thoughts. Any suggestions would be greatly appreciated.
10. Etc. etc.
