Silverback
BoostRetard
So after lurking here for years I have a few questions (after thinking about it I’ll post them as separate threads)…
Those of you doing 4L80 swaps, what are you using for a converter? How do you like it? Do you have recommendations?
It seems like everyone I talk to gives me contradictory information which quite often even contradicts the same company’s published info, so I don’t know what to thing/believe. I’ve actually had 2 different people at ATI tell me that I can use the same converter as the 700r4, and it seems that everyone that I’ve talked to that has one of the converters that I’m considering has some problem with it.
FWIW, in my case it’s replacing a 700r4 that I just toasted, behind (don’t be offended, it’s not in a sy/ty) a turbocharged small block chevy that also sees some spray. The thing is actually driven on the street a few times a week (to work, it’s as close to a daily driver as I have, but doesn’t have to be), so streetablility is an issue, but I’m figuring that I want something with a stall in the low/mid 3K range leaving off the boost, and high 3K range on boost (fairly tame engine, 236/230/114.5 cam, worked aluminum heads, ~9:1 compression, don’t know how much boost it will tolerate in the long run, 3.50 rear gear…)
I don’t know if you guys have even looked into stall torque ratios, but as of right now I’m thinking that I’d like to keep that on the high side since I’m loosing the steep, 3.06:1 first gear in the 700 which did make things fun on the street…
So is there a point? Seems like the transgo HD2 kit is the way to go, but I’m not sure how the electronic control, which I guess can control shift firmness will affect this?
I’m somewhat leaning towards going with the transgo setup, if there are any choices going for as firm shifts as possible and then if they’re too firm “turn them down” using the controller, but I’m hoping someone here has experimented with it to know for sure.
For that matter, what about the B&M (much cheaper and easier to get)?
