The FPR is located on the pass side, rear area under the EGR valve and IC. this can be done without removing the IC but do yourself a favor and take it off anyway, clean it and reinstall. besides when you take it off your going to want to spray some carb cleaner down inside the upper intake BC it's going to be really dirty.....SO OK...remove the IC, remove the EGR valve. Then get yourself a 17mm and losen the nut located on the bottom of the factory FPR be careful not to bend the fuel rail if it's really tight. then get a set of allen wrenches and remove the two bolts the hold it in place. R&R the bolts and line and repeat in reverse order. GOOD LUCK
