No need to change the compressor. No need to change the pressure switches. Take care of any obvious leaks. Get the 134a conversion fittings. Have the system vacuumed and charge 32 oz 134a.
First of all R12 and R134 use a different lubricant oil.If oil doesn't get changed possible compressor failure can occur. R134 runs at a different pressure.That could be just the low side switch adjusting or replacing? Not sure waiting to convert mine have new compressor and seals and oil for ccompressor.
In an optimum setting you are correct. They do use different oil. I used to do half a dozen conversions a year. Its less common now that nearly everything is 134a. Have never changed the compressor or oil. My mothers 87 Marquis went 135k on a conversion I did and the car had 230k on the compressor when the clutch finally failed.
