blade of death
T-n-T
Anybody got a picture of the "B.O.D." installed? I just want to see how much clearance you get... I tried making my own using the plastic storage container, but I think Jim's would probably look more "business-like"!
Tony
typhoon1588
The blade of death drops down probably 4-5 inches lower than the stock piece of crud plastic. In his instructions with the blade, though, the notes that if you can't deal with that little of clearance you can bend the scoop at its halfway point.
Speaking of the blade, if Jesse (HuRyde) happens to glance at this post, I sent out the scoop yesterday (12/24) via priority, so you should have it within a few days.
Mike
turbosonoma
While we are on this blade of death topic. I dont even have one of them goofy plastic deflector things on my lower IC cause it never came with one when i bought it. So do i need that too if i get the BOD?
Brad
92synoma
SeattleSy#1255
Category 5 Conservative
Is there any performance/temp. advantage to having the blade of death--or is it mostly for appearence and durrability?
thanks
jwaller
Evil Genius/SyTy Guru
Jims scoop is definatly a perf add on....helps lower the IC temp by pulling in more air
SyTyJedi
Jedi Council
It definitely directs much more air thru the CCHE than the stock unit. A few years ago on the way home from work, cruising on the highway with only hotwired IC pump and BOD, I frosted over the IC completely. It was quite cold outside, but never did that with the stock piece.
HTH!
Tyler
0-60N4
Brad; you're like many owners, the factory air deflector (skid plate) breaks and falls off early in the life of the trucks. Many people don't even know they are supposed to have one. They are important in managing the air flow though the engine complartment. However, you don't have to get one with the Blade of Death. Either part can be installed and used separately.
I have a new pic of the front of my Ty showing the blade of death. I'll add it to my signature as soon as I figure out how to do that. Otherwise, I can e-mail pics to anyone. Also have pics of wheels and other corvette stuff from Longwith's trim & accessories.
Jim
0-60N4
Just send a check in the amount of $55.00 to:
Jim Longwith
4530 Landmark Dr.
Rock Hill, SC 29732
Thanks,
Jim
