I installed a new roller chain. The old chain was rattling like a mofo. While I was at it I advanced the 422 cam 4 degrees
(I know the 422 already has 4 degrees ground into it and it's supposed to be installed straight up so dont give me shit.) All I can say is that it has more low and mid power then it ever did. The ball bearing t66 spools up just as, if not faster, then stock turbo. The top end power doesnt seem to be hurting like I expected. It seems the whole rpm band has shifted down about 600rpm. Holy cow, what a difference. It's no joke.
The problems is, it has a tendency to knock now. I retearded the timing a whole 7 degrees and it still knocks a little. This has me scratching my head. I know the cam drives the dist. So, advancing the cam must advance the dist as well, right?
Say the old chain was streched enough to retard the cam 4 degrees. When I installed the new chain, and advanced the cam 4 degrees, that would be like effectiveley gaining 8 degrees cam advance. Would this advance the base timing 8 degrees as well? I haven't checked it with a timing light yet cause I don't have one. I speculate this is what is going on and I'm wondering if anyone can verify this is what's happening
