Cobra elbow reinforcement
Ty1642
There have been several good threads on here recently that inspired me to add something (hopefully) also useful.
I added a reinforcement to a cobra elbow to try to prevent it from sucking closed under high airflow. It's a length of threaded rod with washers and nuts on the insides and outsides. It goes across the narrowest point of the elbow, just above the 90 degree bend. When you flex the elbow by hand, it seems that this is the spot most likely to collapse.
The threaded rod is small diameter (10-24?), so it shouldn't have much effect on airflow. I drilled holes in both sides of the elbow that were small enough the rod had to be forced through, so no air should leak. The washers and nuts are all loctited, so nothing should ever get sucked into the turbo. Just squeezing by hand, it seems this has made the elbow a lot more rigid.
Nothing that major, but maybe helpful to someone.
mattw
Re: Cobra elbow reinforcement
I'd use a lock-nut on the outside. Or tack it really quick with a MIG... Would suck for that outside nut to come off and then possibly allow an inside nut and/or washer to suck into the turbo... Cool idea though.. Curious to hear if it works..
Jimmy
Banned
I put a couple pieces of muffler shop scrap U bend tubes in mine. Dude wouldn't take any $ so they were free.
