Hi Guys,
Haven't posted for some time as my Sy has been in the garage under a cover while working on other projects. I bought it two years ago and it passed smog after a tune up, oil change, ect. I took it out of the garge on Saturday, put about 50 miles on it, topped the tank off with fresh fuel- it's sat for 6 mos. or so- and went to the smog guy.
Passed visual and the new pressurize the fuel system test. It failes HC at idle 165ppm on a 120 max. CO was excellent at idle and 2500 and HC was good at 2500. In Ca they can't do a roller dyno test on AWD so they just check idle and 2500 no load.
I have some friends in the smog biz and the first thing he said was Hc is unburned gas (duh) but it didn't mean it was neccessarily running rich so much as it wasn't getting burnt completly especialy sense it passed last time, also it has a new cat. He asked when the last time the plugs were changed and I know these thing consume plugs. He suggested going up one heat range and running as wide as gap as I can get away with for more complete combustion under no load.
I also thought about turning down the fuel pressure- yes the adjustable regulator slipped past the visual- from my current 42 psi to say 36 or so. I'm just wondering if the O2 sensor will see it being lean and try to richen it back up basically defeating the purpose.
Any ideas or thoughts. Thanks in advance.
Al
Al
