Forge Motorsport Billet Wastegate
10wetwillys
if i was going to change the watsegate to the forge ..would the i still be able to control the boost via the stock emc?
i was thinking about keeping the stock boost control solenoid .. pros or cons to that idea?
10wetwillys
Slyclone
Well-known member
Re: Forge Motorsport Billet Wastegate
I don't think it works like that.
All the factory stuff is bypassed.
You set it up to your boost preference with a spring.
My PTE WG I set up for 10# ( on a big turbo ) to be safe. After some diagnostics you can turn the wick up...( my truck is NOT stock).
Couger1968
Dazed and Confused
Not with the springs that come with it. I did try just for kicks and it did not work at all. If they had a 8 pound or lighter spring maybe. I had 10-14-18 springs.
vinnieTy
TY # 1889
I installed the forge wast gate last year and have it connected to stock boost control solenoid and it never worked right. I haven't gotten to the truck yet to work on it but I was told from Tom to not connect the solenoid because it will not work right.
Sportmachines
The whole point of the Forge WG is to provide more consistent and stable boost control. The factory WG solenoid with a stock tune has terrible boost control. It can be improved with tuning. This eliminates it from the equation and bases the peak boost off the rod and spring. HTH
SEL777
One of 101
I would suggest to get more than one spring if you order one. The different (colored) springs will allow different boost levels. Sportmachines sells them and is a donating member. So, support them.
Sportmachines
Thank you! We include an additional spring with all the waste gates. They come with a 12-14# spring, and we include the 14-18# spring
10wetwillys
is there a thread on how to by baypass the stock stuff i looked and could'nt find anything..
should i also put a manual boost controller on?
neildemo
Administrator
I must say the best simplest mod to any Stock truck is this Wastegate. You will never look back.. your truck will get into boost 2x as fast and maintain boost throughout the power range. This is a must have :)
atomicmecha
I hate rust
sounds like the forged plus a manual boost controller is a good combo for a higher boost programming. Use the 14-18# spring with a controller and dial it into the level you want for the tune and enjoy.
