marlborosyclone said:If anyone in the Chicago land Area would like a tank from a Syclone i have one behind my shed that you could have. Just come pick it up it's free.
I am currently using a Race Safe Plastic Fuel Cell mounted in an Aluminum Cradle. From underneath all you will see is the aluminum cradle. This should look very nice. Cost - Not Sure ? The tank is going to be mounted between the frame rails were the spare tire was mounted. I hope to have pics this weekend.
marty-mj
Falco said:marlborosyclone said:If anyone in the Chicago land Area would like a tank from a Syclone i have one behind my shed that you could have. Just come pick it up it's free.
marty-mj
Marty,
Pls post pictures or a location if you have a chance. I'd be interested to see it. Also what kind of pump are you using? How big lines? What's the capacity of the cell and how much does it weight?
TIA,
ghettosled said:if you run an inline pump you can just weld a sump to it. Thats probably the easiest thing but will be a bit louder.
I'm doing this to a sy right now so I could take some pics of the baffles inside now that its out
canadian said:ghettosled said:if you run an inline pump you can just weld a sump to it. Thats probably the easiest thing but will be a bit louder.
Now what's the *safest* way to do this. Obviously if you're using an old tak there are going to be fumes inside of it, and drilling holes and welding could cause a big bang. I'm sure a professional shop can do it, but what if the average back yard mechanic wants to try?
