giving up on Datamaster
phoonrt
dose the type of computer matter on setting the ALDL link timing??cause this sucks, i can't get it to work, and i am hearing more knock these days...also i took the aldl down and everything seems to be connected fine....its like :banghead:
TurboTYPHOON
Are you plugging th cig. lighter in?
Mine didnt work until I did this!
Are you using an USB-to-serial adapter?
Mine seemed to work best @ the 195 setting in the serial Port.
Raist103
Engine Killer, iPhone Killer, Lawnmower Killer
i work late(some times) but i am close by(i even drive by 73 everyday on the way home from work) if you wanted to check your cable on my laptop or ty, i would say my cable on your ty but i just hid it under the dash when installing my white gauges.
Raist103
also forgot to mention that i i really know about datamaster is if the o2's, volts, and knock are good or not.
Loeryder
I set my aldl link timing to 0 and I link everytime.
PIII 600 192MB running win98SE
No Problem, mon...
Captain Morgan
Moderated User
phoonrt said:
alright good, cause this bullshit is making me real mad...thanks
yeah, dont sweat it. go look at my 2 page post in the Tuning Forum, it pissed me off too. we'll figure it out, or break alot of shit like in Office Space :)
phoonrt
sounds like a plan :D --also i have the ALDL tester thing--passes all tests, com is working fine too--i don't get it
InvisiBill
TTS's ALDL tester program may or may not mean anything on my cables. It's designed to test their cables, and I've never even seen one. I did test all of the cables before I shipped them out, but it's possible that something could've happened to it in shipping. If you hook up with someone else, try using their known-working PC and cable in your truck. That will verify that there isn't some problem with your truck's wiring or something. Then try swapping in your cable. If it doesn't work, then there's most likely something wrong with your cable. If it does work, then it's probably a computer setting.
I honestly don't know what all those settings do, but mine didn't work at the defaults, and does work at whatever I ended up on in the 190-200 range.
phoonrt
FINALLY-got it to work, very happy-but not so happy with the data--I have very bad knock...sucks again-i need some help--also i smell coolant when i have the heat on?? :-?
phoonrt
oh yeah and another thing, I just got it to work on my last trial run-now i can't use it again--i tried uninstalling it, then reinstalling it--still gives me cerap about registration--i just wanna do one run--now i can't!!--anyone have any ideas??
