headliner question - syclone
Baythan
SY2TY2SY2TY
Does your headline tuck under the A-pillar molding (where it makes contact with roof) - or does it ride on top of the plastic?
Also, is there a "finish" piece along the FRONT edge - or can you feel the edge of the headliner at the windshield?
Prompt responses sought as I am replacing today.
Thanks in advance.
Steve
13Pelle
Re: headliner question - syclone
There is no trim piece across the front edge at the windshield and IIRC the headliner rides on top if the A-pillar trim panel.
Baythan
SY2TY2SY2TY
Thanks. That's how the stock one was in...just making sure it didn't pop out of the plastic at the a-pillar. :tup:
Putting in an LMC replacement.
thesyguy
Let me know how it works out. I need to replace mine but was unsure of the fit and finish of the LMC part.
Syclone#1992
SyTy.net Moderator
How did this come out? What one did you order? Is it just like the stock one? I need to replace my headliner eventually. Does anyone make a reproduction warning sticker?
Baythan
SY2TY2SY2TY
I posted in the "what did you do to your truck today" a while ago...I ordered a replacement piece from LMC on the advice of a few Sy owners around here (PA). :cool:
It's plug 'n play...stock specs. It has a plastic backing (vs. the crappy foam board). Goes right in and looks great. No more flop. I should get pix. :( Get the black one...not the charcoal.
Downside: It's expensive. IIRC it was about 190 shipped. It's made in China. :tdown:
Upside: it take 30 minutes to do the job.
Hey Tim...PPG FTW!
SY-1193
Sending you a PM.
Guy only has 1 left so I didn't want to post the source. Sorry.
13Pelle
LMC was running a special on the black headliners a little while back for $149 IIRC. I am curious to how yours holds up.... literally. The one Ryan and I installed in "Tex" sagged/bowed down so bad in broke the dome light base plate in two. It was only in the truck for a few months. I will try to get some pics up...hopefully for you and others it is an isolated incident and not a common LMC headliner issue.
Syclone#1992
SyTy.net Moderator
Well, if that's the case, maybe I am better off to get it recovered with the correct material.:squint:
