..........started back doing a little tuning. Truck (92') now is equipped with a wide-band. Symptoms: while out doing runs and tuning; the water temperature eventually climbs to about 200+ degrees. I think this causes the truck to throw a code 13 frequently. The code seemingly doesn't show up until the high temperature. In addition; it is hard for me to tune 14.7 afr while idling. Changing the values in the F28 table either makes too lean or too rich. On some days I have been able to tune up to 18 lbs. of boost without knock; but then the next day without changing anything I get knock. Any suggestions would be appreciated.......
