High Speed vibration issue
Syclone#2960
What ever it takes!!
Re: High Speed vibration issue
That angle though.
The front propshaft is at 0*
& the front diff is at 6.6*
This is with the typhoon resting on all four tires.
gringo76
That angle though.
you cant adjust the prop shaft angle. both ends are fixed. you can adjust the main drive shaft to rear end. you can adjust the rear end pinion angle too match the trans centerline angle, and yes this can cause weird vibrations not just in the seat. might not be your prob but looks like you have checked everything else so why the hell not lol. also have you checked motor mounts?
