TechWeasel
As some of you may know, I recently got my Sy running again after almost 2 years off the road. The problem I'm having now is that the engine idles and revs like it's not firing on all six cylinders. It shakes like a wet dog at 2500 rpm, as a matter of fact. It's also got a surge when cruising at low throttle openings.
To date, I've gone through the entire ignition - it's got six brand new CR42TS plugs gapped at .035, new plug wires that are properly routed so they're not rubbing, against anything hot, or crossed, a new cap and rotor, and a new stock coil. I think the problem isn't in the ignition, because all six plugs looked the same when I pulled them out to check them. They all have just a touch of tan forming arount the top of the insulator, and none of them look or smell wet or oil-fouled.
I have six new RC injectors, and all of them sound the same when I listen to them with my mechanic's stethescope. I did a power balance test today by unplugging the IAC connector, then pulling the spark plug wires from the cap one by one. Each time, the engine dropped revs. I'm not sure just what that means, since the misfire feels regular, but none of the cylinders seemed to make it worse than the others.
The one clue I have left is that the engine is making a sort of hollow knocking sound, similar to the sound made when you "cluck" your tongue against the roof of your mouth. Using the stethescope, I found that the sound is loudest on top of the driver's side valve cover, just forward of the breather hole. I can hear the sound all along the valve cover, but it's louder on the surface of the cover than when I listen to any of the three hold-down bolts.
Tomorrow, I think I'm going to pull the valve cover and see if maybe I have a loose rocker arm. Would having one lashed out of spec make that noise, and cause the symptoms I'm experiencing due to low lift? Also, what's the proper procedure for checking and setting lash, and what's the spec for our trucks? Finally, if I don't find anything wrong with the valvetrain, is it possible I've got a lifter that's collapsed?
Thanks in advance for your help...
