IC brackets where does each go?
sy2185
I've got 3 IC brackets, a horizontal one that attches near the TB, a straight one, and a curved one. My Sy only had 2 of them when I got it and I think 1 was in the wrong place. How do they go(straight one bolts to the front or rear of the ex. man.,and front,middle, or rear of IC?)and which hole in the IC does the curved one bolt to and does it bend towards the front of the truck, or the rear, from what manifold location(front or rear)?
Thanks,
Jeremy
jwaller
Evil Genius/SyTy Guru
the one that loks like a piece of flat stock 1.5" wide goes under the TB....
the other 2 attach to exhaust manifold studs....
they use the 2 stud back on the front and the 2nd stud back on the rear....
I believe the curved one attachs to the front and the straight on goes on the rear.
sy2185
It seems the staright one goes from the rearmost mounting position to the back IC mounting hole.Then the flat one from under the TB to the middle IC hole, and finally the curved one (does the curve arc forward,or back?) to the front IC hole, right?
Thanks so much
Jeremy
