It's just a six
Super Member
Re: L-35 heads.
Thanks for that.:tup:
The heart shaped chambers are supposed to decrease the tendency of detonation, by having more of a quench area, but if your pistons are down the hole, that does not help much.
Not sure what our engines pistons deck heights are, most likely they are down the hole as a guess .010-.020"?
Anyone?
When Josh, A.K.A Tooky installed his 96 & newer Vortec heads, he did not think they suppressed detonation any better than his stock heads.
The LS series engines have positive deck height & part of the reason they can run higher compression.
Thanks for the pics. :tup:
As to your question, I have been wanting for someone to find a junk L-35 head & see if the vanes are solid, if they are I would definitely remove them, it is an obstruction, they (the vane) were made for low speed torque, not for high RPM.
As far as your bowls look, they look like any typical SBC head not a flat wall as a member hear posted they are.
What P.N. are you heads? 181's?
Anyone?
I'm having my ported L35s drilled out for bronze guides and if the vains are solid I'm going to remove them and re flow the heads
