lost instructions for ultimate chip
sy #498
i lost the installation and instruction sheets that came with my ultimate chip. where can i get new copies?
Loeryder
Re: lost instructions for ultimate chip
STG Ultimate Chip Installation Instructions
Install 3 bar MAP sensor (not included) either in place of or near original 2 bar. The stock MAP sensor looks similar to a black soap bar and is located on the drivers side of the engine compartment mounted vertically on a bracket next to the intake manifold.. Remove the vacuum line and electrical connector from the sensor, and gently pull it from the bracket. It will snap out, there is not connector holding it in place. For specifics of the stock 2 bar sensor refer to the Syclone or Typhoon shop manual. Part number for the 3 bar map sensor is 1604-0749 (GM/AC Delco sensor assembly, stock usage was 1989 Turbo Trans Am). The 3 bar sensor is a necessary component, and can be found for $45 - $90. There have been mishaps of people receiving 2 bar map sensors instead of 3 bar sensors. An easy way to check if you have the correct sensor is to observe the stock boost gauge in your dash, as its readings will be incorrect with the 3 bar sensor. The stock boost gauge will not cross from green to yellow at 0 psi, you’ll now remain in the green section when crossing into boost (reading as vacuum). Finally, the 3 bar programs are tuned for a static (no vacuum) fuel pressure of ~50 psi at idle.
Installation of hardware. Remove stock memcal (chip) from ECM. ECM is located behind the glovebox, accessible by removing the plastic panel under the passenger side dash, and passenger side kick- panel. First, the blue cover of the MEMCAL (stock chip) needs to be removed for it to fit properly into the ecm. This can easily be done with a small screwdriver, by prying up the clips that hold the cover on. See photo next page. Notice the orientation of the MEMCAL in the picture below in relation to the carrier. The MEMCAL’s EPROM (black 32 pin IC chip) will be next to the EPROM on the carrier. Once the MEMCAL is attached to the new carrier, you will slide the MEMCAL under the lip of the ECM and then push the carrier into the connector in the ECM as shown in picture. Note that this picture also shows a ZIF socket that is an option for those who have purchases just the hardware and want to program their own chip. Most Ultimate owners will not have this socket so pay no attention to the last 2 frames on the right showing the EPROM being inserted into the ZIF socket.
Plug the carrier into the connector in the ECM from where you removed the MEMCAL. If you have the carrier in properly, the two retaining clips will close as you push the carrier into the connector. The gauge style displays will be shipped without the cable attached to either the carrier or display. The “radar” style, which is enclosed in a 3”x3” black enclosure, will come fully assembled. For gauge style owners only: once the display is installed into its 2 1/6” pod (gauge holder) you can attach the cable to both the carrier and display. Connect the cable to the carrier such that the cable points towards the center of the circuit board, not away from it. The correct end of this cable has the exposed shielding nearby. Once connected, put the cover back on the ECM and replace screws. The exposed shield on the cable (gauge style only) will be “crimped” between the cover an ECM shell. This is for grounding purposes of the shield. On the display end, insert the connector into the back of the gauge, with the cable pointing downward or away from the center of the gauge.
At this point, you can turn the ignition key on, with engine off. Make sure the check engine light stays on steady, which is normal. If you have a scan tool, you can read the PROM identification’s (Prom id’s) by toggling the switch through the positions. Every setting will have its own PROM id. These steps will verify that all is working properly. You can start the truck at this point and the check engine light should go off and the truck should run normally. You can try the security position if you have this option and the truck will not run. The valet program will not run the intercooler pump, which you can also verify if you wish. This program also has the timing advance reduced significantly and a 4000 rpm limit, making it a part throttle only program. Programs can be changed while truck is running or shut down.
Once you’re satisfied that all is correct, shut down the vehicle and run the ribbon cable/switch to wherever you want to locate it. Re-install the ECM up behind the dash. The “radar” style display can be located in many places, on the “tray” below the ashtray, or in the glovebox have been a couple popular choices. If you wish to locate it in the glovebox, there is a small access panel in the back that can be removed, allowing the display cable to be run inside. You will have to remove the cable from the display first, by simply removing the display cover and pulling the cable out of the connector. After running the cable into the glovebox, reconnect the cable into the display unit and replace the cover. Make a note of the connector orientation before pulling it off so that it can be reinserted the same way.
Operation: Once installed, operation is very straightforward. On the “radar” style displays, the left button will toggle forward (up) through the settings, from lowest boost/timing to highest. The right button will toggle down. On the gauge style, the opposite is true, right is forward (up), left is reverse (down). The display will indicate the current level of timing and boost, or any special settings contained in the chip, such as security (SEC) or valet (VAL). The timing is indicated by the first two digits, as T1, T2, or T3. The larger the number, the more advance in the program. T1 is a level similar to that of the stock calibration, and will be safe to use with premium fuel at boost levels up to 17-18 psi on a stock vehicle. T2 has a couple more degrees of advance, throughout the rpm range and will require more than 93 octane at the 18 psi and higher boost levels. The T2-16 and T2-17 should be ok to use with 93 octane or better. This is up to the user to determine by monitoring knock, as it will vary from vehicle to vehicle. T3 has a couple more degrees advance than T2 and will require additional octane to run safely.
The boost level is indicated by the second 2 digits of the display, as the value in PSI (16, 17, 18, etc.) Note that the 24 psi programs will drop approximately 1 psi at WOT above 4800 rpms, to 23 psi. For those with stock turbos, keep in mind the limits of this turbo. The boost levels above 20 psi might not be reached due to the small flow characteristics of the stock unit. Also, due to its inefficiency above 20 psi, horsepower gains will probably be minimal above this level even if you are able to attain them.
The unit can be “locked” or “unlocked” by entering a code by pressing the buttons in a certain order. This disables/enables the pushbutton switches until the sequence is again entered. To do this simply push both buttons at the same time. Four “X”s will appear, indicating that the request is recognized. Then the word “open” or “lock” will appear, depending in the current state. Then the word “KEY?” will appear at which time hit the “up” button twice, and the “down” button once. Each time one is pressed, the word “KEY?” will momentarily disappear, indicating that it had recognized the code being entered. After entering the code, there will be a 3 second pause, then the word “LOCK” or “OPEN” will appear, depending on its new state. A moment later the current program setting, T1-15, T1-16, etc. will reappear.
This may sound complicated at first, but once it’s done successfully it is simple to execute.
Programs can be selected or switched at any time the vehicle ignition is on. The display/switching unit requires power to operate and will not change programs without being powered up.
The best method of setting the security (SEC) program is to shut the vehicle off in whatever mode you were using, then turn the ignition on with engine off and toggle to the SEC program. Use the method described above to “lock” the unit, and turn the ignition off. The vehicle will not start now and the settings cannot be changed. To run the vehicle again, turn ignition on/engine off, unlock the unit as described above and toggle to desired program. Vehicle will start in a normal manner at this point. Many users have found that they can simply toggle to SEC to shut the motor off, then lock the unit. This effectively does the same thing as turning off the ignition key, which is shutting down the ignition/fuel system and saves them a step in the process.
The Valet (VAL) program is a part throttle only program. It has an rpm limit of 4000, no intercooler pump operation, and significantly reduced timing. If an attempt is made to run at WOT (wide open throttle) the truck will sluggishly accelerate to 4000 rpms, then hit the rpm limit, shutting off the injectors. The truck will behave normally during all other operating conditions.
Programs for the stock injector chips are accessed sequentially in this order: SEC, VAL, T1-15, T1-16, T1-17, T1-18, T1-20, T1-22, T2-16, T2-17, T2-18, T2-20, T2-22, T3-20, T3-22, and T3-24.
Loeryder
This STG product is intended for off-road use only and is not legal for use on public highways or roads. STG and its distributors assume no responsibility or liability for damage or injuries which may result from the use or installation of this product. Take proper precautions before experimenting with boost levels and running the T2 and T3 settings with pump gas. Premium fuel (91 octane (R+M)/2 or better) is required for the lower boost street programs. How much boost/timing can be run on pump gas will vary from vehicle to vehicle and is up to the owner to determine, preferably by use of a scan tool. If the turbo/intercooler has been upgraded, more timing/boost is theoretically possible due to increased efficiency. This is the responsibility of the user to determine. The street/strip settings (T2) can be used by some with pump gas at lower boost levels (16-17 psi). The only sure way to determine this though is to monitor the engine parameters with a scan tool. Safe boost and octane levels will vary from vehicle to vehicle. An accurate boost gauge is highly recommended for any Typhoon/Syclone, otherwise boost levels are just a guess due to the inaccuracy of the stock gauge.
If your boost levels vary significantly from what is programmed into the chip, there are several possible causes. It is normal for boost levels to vary between +/- 0.5 psi from the levels indicated on the boost setting sheet. One cause for significant variance could be that the wastegate rod is out of factory spec. This can be changed by lengthening the rod (lowering boost) or shortening the rod (raising boost). Typically, an out-of-adjustment wg rod will result in a boost curve which either under or over-shoots the programmed level and then slowly creeps to the proper level. Another cause of poor boost control is leaking vacuum hoses going to and from the turbo/wastegate/wastegate solenoid. This typically results in overboost that may or may not be controllable. If you suspect that your hoses are old and brittle, now is a good time to replace them. Significant ignition retard will cause erratic boost control. Also, keep in mind that the stock turbo and wastegate system was designed with the backpressure of the stock catalytic converter and muffler in mind. Once these items are altered, it can affect the ability of the ECM to control boost. The 3 bar chip will do a good job of compensating for these type of situations, but cannot compensate 100%. One event in particular to be aware of for those using the stock turbo/wastegate who have altered exhaust systems, is acceleration while cruising resulting in a downshift to first gear. The sudden rush of exhaust out of the engine is too much for the stock wastegate to bleed off and boost spikes are common in this situation. This situation is not related to the 3 bar or any other chip but is a characteristic of the stock turbo system. Typically, aftermarket/upgraded turbos will come with a properly sized wastegate and this situation should not be a concern.
EGR is in operation only in the Valet and 15 psi T1 program, it is disabled in all the others.
Remote Knock Indicator (“Radar” style only) You will see an 8’ - 2 conductor cable coming out of the display. Run this to wherever you want to locate the LED knock light, which will be separately attached to the display during shipping. Drill a small hole large enough to slip the LED leads into, set the LED into this opening and attach the LED leads to the 2 conductor cable. Note that the short lead on the LED is positive (+), and needs to be soldered or attached using the supplied butt connectors to the lead tagged (+) on the cable. Once done wrap electrical tape around the leads on the back side of the LED to keep it tight and in place in the opening.
Trouble-shooting. If the truck does not run properly there are few common installation mistakes. First check that the memcal is plugged into the piggyback carrier correctly. Check that the EPROM (black chip) is fully inserted in the socket. Make sure you are using a 3 bar MAP sensor! Finally, check that the chip carrier/memcal combination is fully inserted in the ECM and the retaining clip isn’t binding the ribbon cable or preventing the chip from being fully inserted. If these items check out then you’ll need to contact the names below.
50# injector chips
Programs contained are SEC (security), VAL (valet), T1F1-T1F7, T2F1-T2F7. Boost is set to 18 psi in all the performance settings. T2 settings are considered race timing, with ~ 17 degrees of advance, T1 is considered street timing with ~ 14 degrees of advance. F1 will be leanest and F7 richest fuel setting. The fueling differences between these programs are only present under boosted conditions, meaning that it will not change the fuel calibrations at idle, or under regular driving. This allows for some flexibility with different modifications, while allowing for a more custom calibration that is easily changed.
Boost control has not been fully integrated into these programs as much time was spent with the fuel and timing in the calibration, and at this level, many different forms of boost control are being used.
Fueling is open loop for all programs except valet, this was changed for drivability concerns. Running in this condition CAN damage the catalytic converter. Valet mode now serves as emissions program now too.
Feel free to contact us at ty1548@yahoo.com or briang@syty.net for any questions concerning this product. For more information go to www.chitownsyty.com and look for the link called “Tech”. This site will also give information on the latest updates and additions to the chip lineup. Also, www.syty.net is a good resource for finding the latest updates as well as technical support.
I have the word doc with photos if you want me to email you a copy.
These might be old but the hardware install is still the same as it always was.
SY2932
Administrator
Write up with pics here. Don't let the two bottom pics of my polished ECM blind ya :lol: . HTH's
