I know its sacrilege but screw it...its a race truck![]()
Sacrilege? If you were a real racer your exhaust would dump off the turbos out the front of the fenders right behind the headlights.
Truck is stunning. Do you have a build thread on it anywhere? I'd like to see what you did to massage/smooth the firewall and the specs on the LS motor (if you care to share).
Not to thread jack, but where did you find the C5 Z06 wheels, and how much were they? Cheapest I can find them (for legit OEM Speedline or Alcoa wheels) is $250 ea., in marginal shape.
Stock bed weights 230lbs
FG bed weights in at 55lbs unfinished.
Total savings of 175lbs. at the most.
Realistically gunna save about 150lbs.
:tup: Do you have a weight goal? Or just remove as much weight as possible?
I should be at about 3000lbs total race weight w/ 10 gallons of fuel as of right now.
Now Im gunna find some manual window doors and gut them out clean.
A chromoly cage should add about 60-80lbs.
Thanks for updating/posting about your build. Quite a few folks dont visit or publish these days with facebook and such. :tup:
If your interested in reading about other similar vehicles check out:
http://gmcsyty.blogspot.com/
BTW is your Syclone still AWD? Jamie Hacking hasn't release his latest changes for awhile but I believe his 2wd Syclone
is weighing 2750 pounds. With some more plexiglass, ceramic, and carbon fiber you might even get below your target.
Jason Leach's tube chassis might be the ultimate weight reduction (if really really serious).
Larry B.
LS7 Typhoon
Awesome, I appreciate the update. Out of curiosity, is that a Flaming River steering shaft into a manual box? If not, whose shaft is that, looks really well built.
Bruce,great to see the progress with the project. Wow! Nice build.
Thanks Adam...Its a circus/rodeo show trying to juggle everything at once.
I wish I had another set of hands helping me. I might take a week off on this and get my income taxes done.
you planning on having it ready for t2k14?
More info on this please. Trucks coming along nicely!
