Re: need help on rough idle on 93 typhoon
First, I'd check plugs/wires/ignition as suggested. If it's really bad, I'd start looking at the lower intake manifold, and upper for a leaky gasket. Next, I'd start looking at the injectors...perhaps one is dripping instead of spraying?? You'd probably see a crack or missing bit of plastic on the injector after pulling it. GL bro.
