MikeRenz said:If i run it thise way, should i cap the ports or lets them breathe?
my question was more pointed towards "will capping it build pressure inside the water ports"skata said:MikeRenz said:If i run it thise way, should i cap the ports or lets them breathe?
how about you fill the water passage with oil and then cap it off. this might help dissipate heat.
turbodog said:I would think that capping the turbo ports with water inside would result in the water boiling, extreme pressure? Turbo housing is probably strong enough, but why risk it? I'd leave one open.
turbodog said:The oil would ony absorb a little heat... then, as soon as it is at the same temp as the surrounding metal, any advantage goes away.
turbodog said:OK, whatever...
just some info to help prevent a problem:
coefficient of expansion of oil = 460ppm/degreeF
so if oil gets 300F hotter from fill/seal to full operating temp, it will expand ~14%. So, only fill cavity about 75% full, max. Gotta leave some room for air to be compressed by expanding oil.
and, FYI:
Thermal conductivity of oil = 0.15 W/meter degreeC
Thermal conductivity of iron = 80 W/meter degreeC
so iron conducts heat ~530 times better than oil... meaning that the iron will have conducted the heat around the water cooling passage long before the oil conducts it throuigh the passage.... but, decision is yours.
libertysyclone said:Thanks for the physics lesson.
biggtime said:Tell me more Dr. Science!
