Remove the 4 bolts on the fuel rail thats attached to the lower intake. Remove gas hard lines that are attached to the rail and FPR. take off the clips that hold the fuel rail to the injectors and gently lift the rails from the injectors.
When you remove the lower intake, unbolt starting from the center out and make sure you use baggies to lable the bolts and studs....
