there is a groove cut in the stock balancer, but mine also has a white line on it....the previous owner had no idea what he was doing (not saying that I do either! :rotf: )
but without actually finding TDC with a piston stop etc, which one should I use? setting timing at 0, with brown wire disconnected of course, using the white line....engine idles real rough. Just wasnt sure if the white line was from the factory, or the grove to set actual initial timing
