Ok, So Jim Sloan and I installed a 2800 locking converter about two weeks ago... Simple swap. Now the problem I'm having...It will only shift through gears at 4500-5000 rpm. :banghead: Doesnt' matter if it is partial throttle, full throttle... That is the only place it will shift. Then when you slow down, it won't shift back into 1st unless you manually shift it all the way down. I've played with the TV cable and it makes no/little difference. Tranny fluid is at the right level....Had a little too much in there but drained some out and that didn't make a difference.
Can anyone here please please please help :angel:
