Trans Fluid Replacement
QUIKSUV
Planning on installing a deep trans pan soon with B&M 24000lb trans cooler.
Some questions:
How many qts of trans fluid do I need for a regular fluid change with the stock pan? I think it is 5 qts but just want to confirm.
Would you add the trans cooler in series with the stock one or bypass the stocker?
How much fluid does the B&M cooler hold?
Thinking of Red Line synthetic trans fluid. Any comments on fluid?
Loeryder
Both very nice upgrades!
Stocker holds 5 qts with a pan drop, Derale will be closer to 7.5-8.
B&M cooler won't hold over quart.
Run it in series with the stocker.
I use Mobil1 ATF with no additives.
Happy boosting
AXXE
I had a line break at the track last season and drove home with the tranz slipping bad. I fixed it and filled it with B&M Trick Shift synthetic. It has been fine ever since. The B&M synthetic is cheap at Pep Boys.
