On 2002-02-07 10:23, 4C FED wrote:
On 2002-02-07 09:04, myclone wrote:
Lines are 5/16" OD. The braided line size you need is -6. The threads in the trans (NOT the brass adaptors.. the trans case itself) is NPT.
Lemme get back to VA and I'll pull some out of a 700R4 I got laying around to see.. I've had them out years ago and and was going by memory. We ALL know how bad mine is (CRS).
I took my fittings out, cause I wanted to switch to braided steel, and it doesn't look like they are tapered NPT.
Maybe a straight NPT?
