Okay, I may not be the brightest guy in the world but my truck is driving me crazy!! :rant: I will appologize up front for the length of this thread but I need to vent.
I bought a gorgeous 1993 stock Typhoon about a year and-a-half ago. It's been my dream to own one of these fine machines for over 10 years. Anyway I loved the truck until I had the ATR Stage 3 kit installed. This included:
TE 44 Turbo
160 Thermostat
3" Downpipe
ATR External Wastegate
7th injector--I can't believe they still make those
3" Mandrel bent exhaust
Aux. Intercooler (that blocks the radiator and causes the truck to overheat)
Transmission Cooler
Pitbull chip
And a bunch of other junk that I would like to forget.
Anyway, the truck ran awfully until I found SyTy.net and you guys have been great!
After finding this site (and saving more $$) I ditched the 7th injector in favor of some 50lb injectors and bought a chip from a recommended vendor. I was excited and could hardly wait to drive my truck. Well, it knocked so hard that I thought I would blow a headgasket. You could feel and hear the truck knocking.
I didn't drive the truck for two months and I saved more $ and bought a Laptop and DataMaster. The laptop showed that I was getting up to 20 degrees of knock!! :rant:
I changed the spark plugs (gapped to .35), coil (MSD), rotor, wires, checked the vacuum lines and proceeded to get a mere 18 degrees of knock--yikes!!
Realizing that I was in over my head I found someone who knows about these trucks. He took it drove it for a week, tweaked the fuel pressure, changed the bleeder valve, changed the setting on the thumbwheel and said that the truck was getting a little heat soaked because it has been so hot in Michigan lately and recommended that I get a smaller heat exchanger. The truck ran great--for a day!!!!!
Two days and 20 miles later the truck is overboosting big time! I disconnected the vacuum line on my ATR external wastegate in an attempt to set my base boost level and got 19 degrees of knock with the boost turned down!! I don't think my wastegate is working at all. I was thinking about getting either an ITS Minigate or a TIAL. However, I can't find a vendor who has a TIAL in stock. What size fits out trucks? Is the difference in price worth it?
Interestingly, the DM file shows that my RPMs will spike to 6350 and then drop to 2000. Help!! I had another DM file that showed the same high RPM phenomenon in one frame and then a drop in the next. I ignored it until it happend two more times and then I changed the plugs and it seemingly went away. Now it's back.
I would love to post the files for someone to review but I am not sure how. Sorry for the long thread but I'm very, very, very frustrated.
TE 44 Turbo
160 Thermostat
3" Downpipe
Transmission Cooler
Pitbull chip
