On 2001-11-03 00:15, NASTETy92 wrote:
Yeah you can run the 275/45/17's up to a 315/45/17.
I'd be surprised if you could get a 315/35/17 on that wheel... At best its prolly no more than a 9.5" wide wheel... The 315s are intended for the 11" wide wheels.
U can quite easily however run the same size on all 4 corners 275/40/17s They are intended for that width wheel.. IF I am NOT mistaken I believe that is a Camaro wheel and NOT a Z06 wheel.. They are different sizes front and rear, and also I dont think the lugnut spacing is the same as our trucks.
However the 93-01 Fbody wheels are a direct bolt in..
I have 275/40/17s on the front of my chromed ZR-1s
and 315/35/17s on the rear of that same wheel. Major difference is, that the fronts are 9.5" wide and the rears are 11" wide..
One major minus, nobody wants to run ya when they see the 12" of rubber on the rears :wink:
Oh well I've been wrong before but I'd certainly check into putting a 12" wide tire on a 9.5" wheel.. Unless you get the wider wheel in the rear I dont think it will work correctly
