zr-1 wheels question
Opleezz
I have been told that with the rear you need a spacer on them, and it is alot of money, i know a lot of you guys have them on your trucks so let me know...
Opleezz
So tell me, the only thing i am finding is the replica wheels, are there any places where i could find some that arent replicas? cause im not finding them....
eqs_sy
Well I just bought 91 OEM zr1 rear wheels with tires. They will fit perfect without spacers and are the correct offset 17x11 36mm offset 315x35x17 tire size.
Check the corvette sites.
0-60N4
The front needs a 17 x 9.5 +56mm offset.
The rear can be either 17 x 11 +36mm offset
or 17 x 9.5 +38mm offset. The 11" will be a perfect match to the front on offset, the 9.5 will be set inside by less than 1/4", so no spacer will be required.
As for OEM vs. Replica; you can shop around for OEM but if you find a set in perfect condition they will be expensive. You can find some less expensive but ususally they show their age. The replicas I sell are by Original Equipment Concepts (O.E.C.) who was one of the OEM wheel suppliers for the corvette so you know the qualitiy is good. They carry a lifetime warranty on the structual and the price is right. Let me know if you need prices.
Jim Longwith
