truckins10
Ive had some good suggestions from some list members already which have helped but not completely correct my problem. My BLMS were at 148 and knock was always around 6-9KR. After installing rebuilt injectors the BLM is at 140 and KR is down to 2-4. What should I attempt to do to lower my long term memory to 128. Her is a list of what has been checked and done......
-no vacum leaks
-new oxygen sensor
-fixed exhast leaks upstream of O2 sensor
-FP set to 47psi base
-FP rises with boost
Cnat think of anything else right now, but im already running rich at idle. BLMS at idle are at 100-110, at WOT there at 140-143 like I said before. Should I be concerned about this???? Thanks ahead of time. Fern Sy#477
-no vacum leaks
-new oxygen sensor
