coupecustom
I've recently got my Typhoon up and running again, and have my first big issue that is preventing me from driving it.
Durring the redo process of my truck I upgraded the electric fans to the syty performance one. I bought it used and it seems to be working flawlessly. I also moved the battery to the back, because there was no room up front. I also installed a new battery. Last week when I ran the truck and took it for the first drive in months I noticed that the power was dropping electrically. It was raining out and so the window wipers were just getting slower and slower.
The next day I tested the electrical system and found that at the alternator the voltage continued to drop. While running it went from 10.6 to 10.58 to 10.55 ect. So, I figured hey, the alternator must be bad or not have enough power, now that the fans were hooked up. So, I bought a new alternator....a powermaster 140 amp.
Installed the new alternator and charged up the battery, since it was a little low from before. Started the truck and I can still see the volts just drop from the alternator using my volt meter. It started out at 13.9 and over the course of five minutes dropped all the way to 12.3 volts. I felt the alternator, seemed hot, not sure if it should be hot or not, but it was warm.
The relay system for the fans that I used is from the hollisterroad company.
http://www.hollisterroad.com/proddetail.asp?prod=D4060GPT10MTFK
It specifically says to not lengthen the power wire, but obviously with my battery in the back this was not an option. Could that be the issue? I wouldn't really think that a lengthened wire would have that much of an effect but :dunno:
So need some suggestions here.
I've tested with just the key on, and theres no drop...well there is, but it takes a long time to even drop .01 of a volt.
Wiring for the relocated battery is as follows:
Positive to starter
Negative to chassis
Alternator to starter and to power block
Power block to fan relay
chassis to engine
chassis to core support
fan negative to core support
Thanks for any suggestions.
Positive to starter
Negative to chassis
chassis to engine
