Question about turbo
GoldZenkiS14
hi guys im going to be using a stock turbo from a syclone on my car .. i was wondering if the stock turbo has an on center turbine housing and if anyone has any info on that .. i wanted to know what is the stock wastgate set at?? And i also need to know if someone makes a flange for the exhaust outlett or if its jsut a universal one .. thanks hope u guys can help
Carlos
Turbo_xtreme
Re: Question about turbo
Hi i am new to this site and i dont own a syclone or typhoon but i am currently turbocharging my 02 S-10 XTREME. i have bought some parts from a syclone such as the turbo and exhaust manifolds and crossover. but my question is what are the specs on the stock turbo. and syclones rule and XTREMES should have been the syclone II
ZMann
vertically challenged
550 CFM for the stock turbo right? Also, if you push them past 20 psi, they like to heat up. :)
Flyin Ryan
hated cuz he drives fords
stock turbo is = Mitsubishi TDO-6 - 17c/8cm2
550cfm is correct from what i've read but many say that the stock turbo is really inefficient after 20psi
Ian Turgeon
Cascading Inspiration
Sorry about the size... below is the stock tdog-17c compressor map
VermontTy
Support Our Troops
Except for the lack of horsepower, and torque, and traction, and rarity, and prestige, and....
GoldZenkiS14
guys this is old but i ended up using the turbo no my car .. it is a 19c not 17c anyone have specs on that?? also whats the lowest i can set that wastgate rod to?? i have it right now at 6psi and then have a spring jerry rigged to hold back boost and im scared if i take it off and have the rod as clsoed as i can itll be to high and blow my motor .. any help thanks
carlos
