Stock size/length Comp Cams Pushrods
I used these for about 1500 miles. They are 7.200 x 5/16. They are the stock length and diameter pushrods specs. They are hardened so they can be used with guide plates (I never used them with guide plates)
http://www.summitracing.com/parts/cca-7608-12
The reason I am selling them is my Vortec head have shaft mounted rockers and the preload is set with the pushrod length. After resurfacing the heads, I ended up going slightly shorter pushrod for the correct preload on my lifters.
$55 shipped.
killa66cam
RIDIN DIRTY
Re: Stock size/length Comp Cams Pushrods
I forgot about these. If you don't sell them, I will get back with you next week.
Cam
