Boost in Park
Sy370
hey everyone
I have a strange problem, i am getting boost in park, just reving up the motor and it will boost. I did the normal tune up and found a problem where it looked like my fuel was cutting out at high rpm, so i thought that i might have messed up a vac line, so i replace the vac lines and now i have this problem. :rant: to top it off it seems like i still have the hesitation. any ideas?
________
ALASKA DISPENSARIES
crashing_sux
Blow Me?
Re: Boost in Park
Sounds like you're running lean or too little timing. If you haven't done anything that can affect your timing have you verified your fuel pressure regulator has a good manifold vacuum signal and that fuel pressure is properly adjusting with MAP changes?
Sy370
Re: Boost in Park
i haven't done anything to mess with the timing, i have base fuel pressure set at 49 lbs. how would i go about checking the vac signal and map changes. I appreciate the help.
________
Volcano digital vaporizer
Sy370
Re: Boost in Park
no tach flutter, it does it in park, like its running out of gas? it never dies just stumbles then it starts to build boost?
________
Website Host
Re: Boost in Park
Boost can be only be made under load. A free rev engine will not build bopost. You can create a load on an engine with a Rev limiter. If your problems aren't creating a rev limiter, then I would guess the boost gauge off (are you using the factory boost gauge?)
SeattleSy#1255
Category 5 Conservative
Re: Boost in Park
problems may or may not be related...the boost in park i'd guess has something to do with the vac. lines you messed with. Something may be backwards, espically near the turbo/selenoid connections, or there could be a leak?
stock chip has a boost cut off. Perhaps it is something that simple?
I don't know, throwing out ideas.
Sy370
Re: Boost in Park
i am using a autometer boost gauge, i can hear the turbo spool up under the hood, when i am standing there, reving it up. i was chasing a hesitation down when this all started, i did the normal tune up, then i got the hesitation, replaced vacuum lines and still have hesitation plus this???
________
Buy vaporizer
Sy370
Re: Boost in Park
i hear it spool under hood, it seems like the hesitation happens right before it starts to spool, i don't know if they are connected or not. might have to sell this thing auughhh
________
Honda Shadow 600 history
crashing_sux
Blow Me?
Re: Boost in Park
Mine is starting to do that as well, just cruising through my parking lot but no boost is showing. From what I've heard it is a sign that the turbo may be failing.
crashing_sux
Blow Me?
Re: Boost in Park
Nope, I can just hear it whine. Didn't always do that but these things do need rebuilt from time to time.
TurboTony
Re: Boost in Park
Lets start with the basics.
Where is your boost gauge plumbed into. As in before or after the throttle plates.
Tony
Sy370
Re: Boost in Park
it is plumbed into the line that the brakes, so after the throttle plates.
________
Vapir No2
SpoolingTurbo6
Re: Boost in Park
Chip?
Truck stock?
chip change since / or right at time of prob ?
what does the boost gauge read (motor off)?
To check for a bad turbo, 1Take off the inlet to the turbo,2 take a flexi mirior (Idiot Zone) inspect turbo impellare blades for cracks chips ect ect),3 take two fingers and grab ahold of the theaded stud in there....wiggle <----->,4 push and pull on the same shaft forward and aft. (lenght of truck) (horazonaly) 0.040--to--0.060 is on the verge of BAD it will wiggle a little, all do.
5, while you have the inlet off start truck(be sure everthing is clear of turbo!) listen to the turbo inlet for the tell tell CHIRP CHIRP CHIRP of the fins hitting the compressor housing.
POST BACK with results
Sy370
Re: Boost in Park
Thanks for the info on checking the turbo, I have fixed the problem, it was the wrong map sensor. I am going to still check the turbo. I have a superchip, I am working with Dig on a chip. But it seems like I might just have everything fixed as of now....but we will see how long that lasts.
________
HOME MADE VAPORIZER
