nognluv said:also can i put a bar3 map on stock chip. keep info
BLACK92TY said:don't know why all these responses and nobody has pointed towards ignition. sounds like igniton to me. these trucks are so touchy when it comes to ignition its not even funny.
i had an identical problem the first year i owned my truck. truck would stumble and there would be tach flutter under partial acceleration. WOT it ran good but not 100%. coughed out black clouds of smoke too. replaced plug wires and plugs religiously. cap, rotor, tps you name it. still nothing.
finally i was just pissed. tried to go over the checklikst of things i recently changed. so i changed the coil and it was like "hello!" truck ran flawless afterwards. looked like it was arching out on something. turns out i thought changed the coil recently but i didnt. moral of the story... leave no rocks unturned.
BoostedSUV said:everyone pointed me in the dirctetion of ignition as well and i spent hundreds replacing everything and it did nothing. I bought an ECU from a member on the forums who was selling one, and I got the EPROM from todd at SyTy.com. $100's later problem Solved!
QUICK STORM said:it probably could be a bad ground, ecm, etc...
QUICK STORM said:well then i would try a new ecm and/or make sure your ultimate is seated properly, sounds to me like the ecm has a glitch
