E-RUE said:I dont see any fueling tables that account for IAT?
e
sytyguy said:Now, F31M.....the most overlooked fueling table, and probably the one you'll wanna look at the most. F31M uses a BPW scalar based solely on MAT temp.....so you could have a reduction in fuel delivery based on a drop in MAT temps. Figure out the average MAT temp with and w/o alky and design the map around that data. Just make sure to give some fuel lead-in and lead-out, so that you don't have abrupt fueling spikes (could lead to rich/lean jumps that promote detonation, etc....). Also, keep in mind that this table uses Kelvin for the temp range, so be sure to convert the temp data before making changes.
Hood
E-RUE said:TunerPro is starting to look better and better.....
e
crashing_sux said:How are you guys using TunerPro? I tried to use it but can't find a definition file anywhere so I was able to upload a bin to my emulator with it but am unable to actually make any changes with it. Is there a definition file posted on one of the SyTy sites or for sale somewhere?
sytyguy said:E-RUE said:I dont see any fueling tables that account for IAT?
e
Sure there is.....F31M. Look at what I wrote here (about 1/2 way down):
http://syty.net/phpBB2/viewtopic.php?t=40598
HTHs
Hood
BillC said:E-RUE --
First, the values in F31M table are in Kelvin, not Celsius. Only the column heading is in Celsius. The table from one of BG's 50# bins looks like (turned sideways so things line up easier):
Hot 337.8
136 335.6
107 331.1
91.0 328.9
80.0 326.8
71.0 324.7
63.0 322.6
56.0 320.5
49.3 318.5
43.3 316.5
37.0 314.5
30.5 312.5
23.5 310.6
15.5 308.6
6.0 306.7
-8.5 303.0
Cold 260.4
Second, you can use Promgrammer with an emulator, it's just not quite as convenient as that RT program. Just use Promgrammer to edit and save the bin, then use the emulator software to copy the updated bin to the emulator. The biggest hangup with doing it this way is you might need to turn off the truck before uploading the bin (don't know, don't have an emulator to play with).
As I've mentioned before, if anyone is willing to help me work on a RT version of Promgrammer, I'm willing to try it. I would need to borrow an emulator (or if someone wanted to donate/extended loan one) and would greatly prefer some assistance working on it as well. Unfortunately, my spare time is extremely limited (read: "practically none"), so I don't have time to pursue this solely on my own. Plus, it doesn't really seem like the demand is there for the amount of work that would probably be involved (if there is, let me know).
BillC said:E-RUE --
Hot 337.8
136 335.6
107 331.1
91.0 328.9
80.0 326.8
71.0 324.7
63.0 322.6
56.0 320.5
49.3 318.5
43.3 316.5
37.0 314.5
30.5 312.5
23.5 310.6
15.5 308.6
6.0 306.7
-8.5 303.0
Cold 260.4
