IC pump relay hotwire does not work
leusgs
I just finished installing a shurflo pump, and I grounded the yellow relay wire, but there is no power being delivered to the pump.
The relay clicks when grounded, but there's still no power at the pump!
If I put 12V directly to the orange wire in the relay that leads to the pump, the pump runs, so I know the wiring from the relay to the pump is fine.
Ideas on what is wrong? defective relay?
If I can't solve this I'll just use a new relay and wire directly, but if someone has another idea that would be great.
KDBL1TY
Re: IC pump relay hotwire does not work
Go to SyTy Archives.com. Go to how to. Look under engine . This should point you in the right direction.
leusgs
It seems to be a bad relay.
I swapped relays with one from the drivers side firewall above the brake booster. those relays have the same part numbers... now the pump runs!
Now to find another relay - likely a common GM relay I hope.
Matt
Yeah its nothing special
leusgs
To close this thread off - here are the part numbers for the IC relay. It's very common and used for other (mostly GM) applications including AC compressors, fuel pumps, etc.
orig GM #10034222
Kemparts #AR221
Bluestreak RY-27
BWD #R-646 or R-669
I paid $15 for one locally today.
blackty
THAT is how you finish a 'help' post. Nicely done, eh?...Jim
Matt
Glad to hear you got it sorted out :tup:
Gbodydriver
I had the same issue with that relay.. It clicked and was still bad.. I got a new one from autozone for 9.99.. Glad you got it fixed
leusgs
Thanks. This Ty costs $15 per day in misc parts. Does it ever end? (I think I know the answer)
Matt
when it gets to 1500......................you will know your just about there :tup:
