It is made by FAST, but it should work on any vehicle, as long as you have the right coils.
Basically here's the layout:
provide your EST line out from your computer (doesn't matter whether it's FAST, DFI, or stock) to the eDist module
provide a cam sync signal (this would most easily come from a modified distributor of some sort) to the eDist
power and ground supplied to the eDist
eDist then outputs signals to the coils to fire; best ones to use would be LS1 coils, as they are easy to find, powerful, you can find them with the harnesses intact, plug wires are easily made up.
I have tuned several Supras that run FAST and LS1 coils with eDist, so I know it works. We had problems getting it to run with an oddfire, but I think that is a symptom of the oddfire setup.
So instead of spending hundreds for MSD module, upgraded coil etc, you spend it on finding LS1 coils - should be able to find a set of 8 with harness & brackets for 100-200 bucks - the eDist, for 200-300 (?), custom wires - you need LT1/LS1 style plug ends, I believe some companies will offer the plug ends only, so you can custom make wires. OR alternatively, the NEWER 4.3's have that goofy distributor with oddball terminals - those terminals are the same as the LS1 coils. So if MSD or whoever makes a kit to fit the newer 4.3's, those should work.
Anyways, not *easy* by any means, but well worth the work if you did it IMO.
It's on my list of things to do, which is a long list...
