I don't advise it for everyone.
If you want easy, do the stock intake
I like the looks
I like the single round throttle body.
I like the plumbing of the intercooler pipe to the front
I like the idea of using a single gasket at the intake, possibly even the factory Vortec 4.3 gasket (re-useable).
I like the fact that I'd be able to use any set of newer Vortec heads and they'd bolt right up.
I like the fact that the Ramjet intake will line right up with the Vortec heads, no huge mismatch, and the intake runners are large enough to make use of the larger ports. I believe the combination of the large plenum, good size runners, and lack of port mis-match will make for a good performance gain in a Vortec buildup.
Costs? yes it'd be expensive for the average guy, costs would vary. For me? I could get it done fairly cheap. Intake is $350-400 I believe (GM discounted)
Cut & weld the intake- could get done cheap/free from friends/hookups
fuel rails - have a set here, should just have to fabricate mounting to it
throttle body - LS1 throttle body, i have a spare at home
TPS hookup - same 3 wires, just different weatherpack plug, Casper's has an adapter even.
thermostat neck - not a big deal to find a SBC low rise one & custom radiator hose. I may even have a different neck at home.
intercooler pipe - I have had custom ones made, getting a simpler, shorter one made isn't a big deal.
So, I might be able to get it done for $500 total invested (or less), then I could even sell my stock upper & lower intake to further justify that intake.
On the flipside - the stock intake - have to weld it up, have to have it machined, hope you don't have leaks, have to drill & tap the heads (and I'm capt. crossthread - easy to strip some of those holes). So it's not cheap either.
I like the looks
