syclone2910
How do you tell if the engine is an L35??
Falco said:As far as indetify L35 heads, they have a plug above the coolant temperature sender if I'm right.
Lynn D. Brown said:Guys,
From what I've read on the Forum, No SyTy's had the L-35
(balance shaft) "W" block, but some of the later '93 Ty's had
the L-35 heads. Is that right ?
InvisiBill said:Lynn D. Brown said:Guys,
See my previous post. Apparently L35 heads have another bung over the regular heads. People started using this extra bung as a way to tell which heads they had. A while back, someone started a thread to find out just how many of the Ty's had L35s. Turns out like half of them did. BG (I think) made a comment that his company has to do 10 years of research just to change one bolt, so it seemed really weird that GM would just slap on new heads in the middle of the year.
Someone else posted pics of the stock LB4 heads and L35 heads. Internal shots showing that they were definitely different heads. And both had the "L35" bung. In other words, if you have that bung, the only thing you can tell is that you have LB4 or L35 heads. Which I could tell you without even going to the trouble of bending over to look for that bung.
P.S. This means that nobody really knows for sure what engine Tooky has until it's torn apart.
