Nice try, but I will now use your own evidence to disprove your point. First off that site has all common known SyTy castings including the absolute most common known stock LB4 casting, "10144103". So either we all have "marine heads NOT STOCK" or you are simply wrong and trigger-happy to boot with your quick accusations. Secondly, Look at the known L35 casting 14099064 information, it says years 93-94, years the L35 motor was available. Interesting coincidence? Because if you look at my casting # 14099067 it says years 87-92, which perfectly coincides with the years the LB4 was used, long before the L35 was ever produced. I'll allow readers to decide for themselves if that's just a coincidence or not.Stangbeater said:Those are a 87-92 Marine heads. NOT STOCK
I just did a search in Google for "14099067 head" and found two hits.
http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=14099067+head
Then click FORD/CHEVY at top. It is a PDF
Mike Renz is correct that 14099064 are 92-93 L35 heads. However, that really has nothing to do with the topic at hand since my casting number is 14099067.smaug said:it is very possible mike renz is correct and that those are the 92-93 l35 heads..
666 Sothis 666 said:ok well if josh's head are indeed NOT L35s... isnt there an apology in order for that whole BS arguement from last years nats?
Sigo said:666 Sothis 666 said:ok well if josh's heads are indeed NOT L35s... isnt there an apology in order for that whole BS arguement from last years nats?
Last years?
TookyCat said:It seems Kevin (syntax) posted pictures of his heads http://syty.net/phpBB2/viewtopic.php?t=30559 with the same casting # as mine and everyone agreed they were stock LB4s. Anyone ready to draw conclusions about what mine are yet?
ask partyboymidnightbluS10 said:I was thinking more along the lines of the big, fat cat with the "bung" circled. Maybe bdubb had it as a sig pic or something.
MikeRenz said:ask partyboymidnightbluS10 said:I was thinking more along the lines of the big, fat cat with the "bung" circled. Maybe bdubb had it as a sig pic or something.
