So while I went to replace the ign. mod. on the dist. I noticed on the top of the rotating ring piece , the one that is a piece of sheet metal rivited to something else below it & has a point sticking out for each cyl. Was broke & the section that had 2 of the 6 points on it was missing. Like the points representimg 2 cyls. for the hall sw.
So I'm wondering how it ever ran at all & hopeing I found the prob. So I put in a rebuilt Autozone stock dist., which looks alot diff. But ,gee itdon't have broken parts on it.
So it starts right up, shut it off ,then try to start it again & it acts like there's no spark, just cranks. Check spark,loud & clear.
try diff. settingson the idle trim pot ,thats with the DFI (this has helped in the past) no good.
Smells rich, pull a plug , not bad , still just cranks, change DFI for ECM, starts, AF meter jumping up & dn (alittle more than normal)
Hook up DFI ,idels ,acts better. Turn off , won't start , just cranks ( DFI was just fixed, by the way) put back ECM, starts, idles like crap, does stall. A/F not hardly showing. Drive it, idel bad, but misses are gone-HALAULA!!!!!!!!!!. Bearly idles, stalls , but does start right back up, this is the ECM not DFI.
So now :x
'm thinking O2 or knock sensor going nuts???
So now :x
