Posts getting deleted
jwaller
Evil Genius/SyTy Guru
CLONE said:
NJTy180 said:
SHHHHHHHHHH, maybe he'll burn his bra next. :lol:
ewwww. MAN BOOBS.
the only man boobs your goin to see are from BW and Les. maybe potter?
look if all you ppl are interested in is one sided arguments and misinformation why don't we all just go to RR and do away with the BB.
skata
jwaller said:
yes GM does sell a replacement for the sun shell that is better than the torque master thingy.
and no they don't sell a input drum BUT as I stated you don't need it and the fact that they use alum pistons is one huge reason not to buy it. this is THE biggest failure rate of any part I've seen in a perf tranny. if you change the pistons you'll throw off the balance that they claim is so important. but WHO here spins their motor to 9500rpm's? NOBODY!!
so gm sells the sun shell? how much? $50? $60? $80?
the thrust bearing. $5?
the modified low reverse race. $15?
so(referring to the gp) from $220 that leaves maybe $120-$150 for the input drum? right?
that dont seem to bad for a hardened input drum with reinforced shaft that adds some insurance.
then you refer to the aluminum pistons breaking. you can still use the bonded 3-4 clutch piston and the bonded forward clutch piston. if i'm not mistaken, the forward clutch piston is the one prone to cracking. so you only have to use an aluminum over-run clutch piston.
sorry for pushing this subject further. i just want everyone to have a different view of blake's gp.
jwaller
the sun shell is 15 bearing is 5. there is no need for a modified race with the gm system but you do have to change the forward planet support so that you get rid of the crappy thrust washer in place of a real bearing.
and yes you can use the bonded steel pistons in the torque master drum but you don't need their torque master drum..
the bonded pistons are only $5 eaech so why not replace them all? keeps you from having installer issues with lip seals. put those in a stock drum and your fine.
skata
because the torque drive drum has a metal reinforcement sleeve on the inside of the drum to prevent cracks or complete breakage of the input shaft to drum. that is why the torque drive package includes the over-run clutch piston. they machine out the center so that it has a bigger hole to clear the sleeve.
skata
jwaller said:
great thats the one thats most likly of the 3 to fail.
the forward clutch piston is most prone to cracking, starting from the tabs that are on the piston. but you can use the bonded steel forward piston with the drum.
