Zewerr@hotmail.com said:
You can try tightening up the play in the gearbox. It's pretty easy with basic hand tools.
When tightening the set screw and nut assembly on the steering box I noted that the wheel did NOT want to return to center or neutral position. Generally speaking, alot of suspension/steering places suggest that you do NOT make big adjustments here, I only went 1/2 turn and got less than favorable results.
I'd consider having more caster dialed in as well, I did this on my steering box with NO APPRECIABLE results. Then I contacted the people at
www.powersteering.com and sent them my box. I had it converted to a quick (corvette) ratio box and sent back. This still did NOT help. I also eliminated the Rag-joint setup with a steering shaft and pinion bearings from
www.flamingriver.com and that still did not help. All of this was completed after I rebuilt the front end and replaced the idler arm. When I rebuilt the front end I did the complete PST poly kit. So I guess what I can say here is, I DID everything related to the front end that a person can do and my truck still wanders :banghead: the only thing I have NOT done is add more caster other than the stock specs. Once the LS6 conversion is done and it runs again and it is still wandering (I know it will) I plan on this next.
