Re: We need a gas tank engineer
Answer
It captures fuel vapors and prevents them from escaping to the atmosphere and then stores the fumes and recycles them to the fuel tank or engine intake for combustion as needed.
The long and short of it is that it helps to protect the environment and improve fuel economy.
The long of it:
In the late 60's researchers found that 20% of the hydrocarbons in our atmosphere was coming from the fuel vapors exiting the fuel tanks of motor vehicles. To remedy this, California introduced in the early 70's (70-71 maybe?) the first requirements for an evaporative emissions capture system. The fed's required it the next year on all vehicles sold in the US.
Specific to our vehicle, the EVAP system consists of only a few components, that typically work without problems.
1) The fuel tank. Unlike earlier fuel tanks, our fuel tank has engineered-in room for fuel expansion. 10-20% of your fuel tank is not used to store the fuel, but to allow for expansion. That is why the fuel inlet is not at the top of the tank, but down a few inches. This allows for a couple gallons of extra capacity. The vent that runs from the tank to the fill neck was designed to help prevent over-filling as well as providing back-pressure reduction. Some vehicles also have a flap at the bottom of the fill-tube that closes when it reaches it's engineered stopping point. These tanks aren't "full" anymore. If anyone was curious, the expansion of the fuel is why you can drive your car home on empty and it won't start back up in the morning - the fuel volume shrank.
2) Fuel Cap. This is a "non-vented" cap, but still retains a valve that will open up if pressure gets too high or if a vacuum develops. Don't install a vented cap if you are running the evap system, it is not needed.
3) Liquid/gas separator. This is in the fuel tank and prevents liquid fuel from getting ingested into the charcoal (carbon) canister. Usually just a compartment with drain holes in the bottom to allow fuel to drain back out, but I haven't opened up a Sy tank to verify.
4) Separator valve. On some vehicles, not Sy/Ty, there is a separator valve that prevents liquid fuel from transfering to the canister. Basically a float with a light spring on top of it, vapor travels past the valve but liquid lifts it and seals it off.
This design isn't used on our vehicles as indicated by the lack of this valve on the tank.
5) Vapor restrictor. This is placed into the vapor tube to the canister. It limits the amount of vapor that can be pulled by the EVAP canister, really by the vacuum applied to the canister as well as keeping the bulk of the pressure in the tank. If there is a restriction in the line, it will more readily use the fresh air drawn through the canister and retrieve the vapors absorbed by the carbon and not pull vapor from the tank. The goal is to completely evacuate the canister so it can reabsorb the next time the pressure rises.
6) The charcoal (carbon) canister. The activated charcoal absorbs the fuel vapors and stores them until they are "purged" and drawn into the intake manifold. There is a line that runs from the tank to the canister marked "tank", and another that is usually marked "purge" that goes to TB (ported vacuum). This way, there is no problem with adding too much fuel (via vapor) when the vehicle is at low engine speeds.
7) Ported vacuum source. Nobody wants this fuel to over-richen the mixture upon start-up or low engine speeds. EVAP comes on only with ported vacuum, not manifold vacuum. Different systems control this different ways. Mine is long-gone, but looking at the vacuum diagram, this system is as simple as it gets. There really is no "as needed" here. It tries to suck up whatever is in the canister whenever the throttle is opened up. Including ambient air if there is no vapor.
So the "short" of it is that the fuel system was designed to operate correctly only if all components are there and functioning properly. Over-fueling the vehicle (clicking the fuel nozzle over and over) can saturate the canister with raw fuel, which typically is just never going to effectively empty, , "different" tanks, wrong fuel caps and the removal of the charcoal canister or even just the vacuum line will all cause excessive pressure to build and "smell". Since I don't live where it gets to extremely hot, and I don't have a fuel pump that pushes large amounts of fuel back into the tank (causing higher vaporization), I don't have the first-hand experience that maybe you are dealing with. I can say typically, the tank is designed with enough headroom that it can take quite a bit of expansion before needing the relatively small amount of storage the charcoal canister can provide. I have seen tons of these systems removed and operating here (EVAP if not computer controlled was not required) that never experienced over-pressurization. In the end, if the EVAP system is removed, the fuel cap (even a non-vented cap) will prevent more than 1psi from building in the tank.
Pros:
Less smell.
A small increase in fuel mileage due to capture of potentially escaping fuel vapor. Hypermile your heart out.
A little more A/F swings off-dle to let those inexperienced tuners try to correct for. :2cents:
More EVAP capacity to prevent fuel smell. If you are getting fuel being pushed out, you have an overfilling problem or your "seperation volume" has been compromised.
A healthier environment. Impress your hippy friends.
Cons:
Extra Stuff. An engine compartment like Rodney's doesn't deserve a piece of black non-bling.
Extra weight. If the canister is fuel-soaked, it can weigh about 5-7 lbs.
Vacuum line: Another vacuum line that can crack or just simply confuse you when you are reinstalling your intake.
Tuning. Trying to fight this variable fuel addition will drive you nuts. See above.
Doesn't clean intakes. Since it isn't raw fuel (unless something is wrong), it isn't going to help keep your intake tidy on the inside.
