smeagol said:Yep, you are right.
i want specifics.
A truck running cleaned up vortecs, with a 412 cam & 1.6 rockers, ported exhaust manifolds, and an air-air
VERSUS (what he could be referring to)
a truck that is heavier, with a .430" lift cam, L35's, stock exhaust manifolds...
I wouldn't recommend a 72 for the latter. I wouldn't really recommend a 72 for the first one - unless you knew what you were doing. Tony and Nolan know what they are doing. I won't recommend anyone run a 72 on any of my chips - 50# won't support a 72's capability, a 63 is more than enough to run out of injector with the 50s. So judging by the goals, turbo, engine specifics, you can help to decide on a stall converter. If he told us that this truck was his daily driver and he was worried about mileage, I'd throw the 9-11 types out the window.
I have had good results with some combinations, and horrible results with some combinations. I just want to know the whole picture before someone says to use a 9-11 on a mild buildup - I just don't see consistency between those converters, and some trucks just *don't* need that kind of stall converter. I see no reason to run bigger than a 51 turbo on a stock motor. I see no reason to run a small body converter if you aren't shooting for faster than 11.7 or so. I see no reason to run a 72 unless you want 10s.
smeagol said:....tighter 12" body converter 2800ish stall....
Falco said:smeagol said:....tighter 12" body converter 2800ish stall....
Brian,
Any brand you prefer here or have experience with?
TIA,
1quikAWD said:smeagol said:Yep, you are right.
i want specifics.
Mileage is not really a concern, I have 2 other vehicles for that, I just dont want to launch at every light. Before all is said and done, I will end up at least port matching the exhaust manifolds and probally a custom crossover. As we speak, my brother is looking for air-to-air ic's. The L35's are ported and polished, 3 angle walve job an 1.6 roller tip rockers( heads were completely rebuilt in Oct). I would love to see mid to low 12's. I know that the truck is heavier,(truck weighs 4400lbs w/ me in it) but the gears (hopefully) will make up for it(3.73 w/ smaller tires=4.21 gear ratio).
I said the truck will be my daily driver, but not by necessity, I do have other vehicles. I want to terrorize unsuspecting Maros and Stangs, along w/ the occasional stock Ty.
John
smeagol said:Well, judging on those goals, I'd say something larger than a 20g is in order; PTE, custom setup from Mike Lee, or hybrid even. Also, with your 3.73 gearing, I'd rather see you have a tight converter in there. 3.42's are really ideal for the trucks, as the gearing loads the motor more. With a loose converter & 3.73's, you'd shift into 2nd, or almost over-rev, right off the line. We used a tighter converer in the Braphoon - it had 3.42's, ported L35's, mild cam (.430" I believe), stock exhaust manifolds & stock IC. With that combination, response was great, no need to give it extra gas to just idle around town. What cam are you going with ? What boost levels are you going to run ?
Your buildup is quite different than any other syty around for 2 big reasons - 1 - the weight and - 2 - the gearing. Those will definitely affect your decision.
