drain plug in stock tranny pan?
Typhoon #1133
Has anyone put a drain plug in the stock tranny pan before? i am looking to drill a hole in my pan and tap it. so i have a plug to drain it. Is this possible with the stock pan? Do i need to worry about clearance for drill and tapping? And what part of the pan would i put the plug in?
thanks,
Keith
jwaller
Evil Genius/SyTy Guru
the pan is not thick enough to tap. it would be better to weld something to the pan and then drill a hole through the fitting.
typhoonzz
Got Boost?
I purchased a derale tranny pan and it already had the drain plug.
about $80 shipped and well worth it...
HTH
B
Blake
Guest
Yeah, I've got a drain plug in the stock pan until I can afford to get a Derale or a TCI. It is a Fairbank plug but I'm sure Jegs or Summit carries it. I paid $10 for mine but I could just walk in a get it. I can measure the location of mine if you want so you'll know where to drill the 1/2" hole so the plug doesn't hit anything inside. If you want, I'll get you one and mail it to you so you don't have to pay more for shipping than the part costs. It has a special nut on the inside machined for an included o-ring, then it has the "tapped bolt" that goes through the pan with a teflon washer for it. The plug is a 1/8" NPT brass plug. It is sooooo nice not to dump fluid on your head when you change the fluid or drop your tranny 3 times in a week :smile:
Let me know.
Blake
Typhoon #1133
thanks for the posts everyone. if a new pan is only about $80 i think i will do that. where is the cheepest place to get one?
thanks,
Keith
:roll:
typhoonzz
Got Boost?
This is the pan I'm using
PN DER-14104. Ordered from Summit Racing and they list it at $72.50 plus their s&h charge.
This is the text from their page:
Double your transmission's life
GM: TH700R-4, transmission pan
This Derale transmission pan can double your transmission's life by dropping its temperature 20 to 50 degrees. This pan holds about one extra quart of fluid and has heat conducting metal tubes on the bottom. Replacement gasket included.
Sold individually.
[/img]
