NecroWolf
lost marbles member
okay just a few questions to help me sort a few things out.
what oil pump is everyone running on their rebuilds? just a oem replacement or a higher volume/pressure? hardened shaft?
how about bearings? what's the prefered set of bearings for realiablity?
which harmonic balancer?
what size main studs on four bolt conversion? is stock size strong enough or should i have it stepped up one size?
and i need the name or two of someone to port my heads, since i got them off and hate to waste a set of head gaskets.
i'm tryin to order these parts from iraq so i'm sure some if not all of them sound like dumb questions. i know there's more questions i got but i've forgotten them so i'll post them up as i remember.
Thanks Garry
Thanks Garry
