Aeroking
e.i.
Re: Engine flatlines/jumps
yes i did notice a difference in the timing MAP. first off, usually when i lift off the gas on decel, then rpms drop low, the engine goes lean, and it surges. Didnt do that this time. Also it slid nicely right into boost. Only problem was it knocked a couple times under low boost, i would assume because of the high timing. My timing map pulls harder in high boost on the top end. but yours makes it easier to get the inital spoolup.
As for the spring, i run a 5psi spring all the time. Since the solenoid valve isnt a bleeder valve, i can pretty much run any boost level with a low spring.
Maby your finger has vaccume then.. Humm...
Did you notice any difference with the timing map or was it about the same feeling?
Was just the springs in the WG holding 11psi?
How was the drive the other night?\
~Scott
