Typhoon#747
SOLD ITEMS:
Item 1: OEM Steering Wheel.
Item 2: Three Piece Combo.
Item 3: Aftermarket floor carpet.
Item 5: Gauge Surround.
Item 6: Gauge Cluster.
Item 7: RPM brake booster line and boost gauge port.
Item 8: Rear arm rests and map pockets.
Item 9: Right and left kick panels.
Item 10: Set of gas pedal and brake pedal pads.
Item 11: Glovebox Door.
Item 12: Doorman Door Hinge Pin Kits.
Item 13: OEM Center Console.
Item 15: Radio Bezel.
Item 17: Keyless Entry Receivers.
Item 19: Door Handles.
Item 21: Ashtray.
Item 22: Custom Battery Box.
Item 25: Dash Panel.
Item 28: Fog Lamps.
Item 27: Door Panels.
Item 31: Power Window Motors.
Item 32: '93 Roof Rack.
Item 34: ABS Module.
Item 35B: A/C Bypass Pully.
Item 36: Accessory Brackets.
Item 40: GM Firewall Bearing.
Item 41: ABS Bypass Lines.
Item 42: Delco Ignition Coil.
Item 43: Accufab Adjustable Fuel Pressure Regular.
Item 44: OEM Distributor.
Item 45: Oil Pressure Sensor.
Item 47: Power Steering Pump, Filter, Lines, and Cooler.
Item 49: Fuel Injector Harness.
Item 50: Pioneer Harmonic Balancer. Part # DA-2621.
Item 51: Master Cylinder and Brake Booster.
Item 52: RPM Turbo Oil Line.
Item 53: Lincoln Mark VIII Electric Fan and Aluminum Cover.
Item 54: Lower Intake Manifold.
Item 55: A/C Delete Heater Box.
Item 56: OEM Valve Covers.
Item 57: Brute Force Universal Joints.
Item 58: Cloyes Double Roller Timing Set.
Item 59: Fuel Pressure Gauge.
Item 60: Timing Chain Cover.
Item 61: Cladding Mounting Tabs.
Item 63: Cardone ZQ8 Steering Box.
Item 64: Trans Cooler.
Item 65: Upper Intake Plenum.
Item 66: Oil Filter Housing and Lines.
Item 67: Front Prop Shaft.
Item 69: Tough One Starter.
Item 71: OEM Door Lock Actuators.
Item 72: OEM Door Handles & Door Lock Switches.
Item 73: OEM Steering Column.
Item 74: OEM Shifter Cable.
Item 75: Hatch Release Solenoid.
Item 77: OEM Window Regulators.
Item 85: Jeep Cherokee Steering Shaft.
Item 81: 3" Down Pipe.
Item 82: Rear Sway Bar.
Item 86: Fuel Pump Assembly.
Item 87: Melling High Volume Oil Pump.
Item 90: OEM Front Brake Lines.
Item 92: Sylvania Headlights.
Item 93: Hood Prop, Latch, Support.
Item 94: GMB High Performance Water Pump.
Item 96: Wiper Motor.
Item 97: Front Axles.
Item 98: Keyless Remote.
Item 99: Breeze Constant Torque Clamps.
Item 21: Ashtray.
Item 28: Fog Lamps.
